Results 1 to 14 of 14
    Classifieds Super License swiftdrivr's Avatar
    South Carolina
    Liked: 673
    Default Costs of kinetics
    Trying to attach pictures from phone
    Swift DB-1
    South Carolina
    Liked: 673
    Default Try 2
    Okay, I got over-brave and under-talented at VIR, and spun into a tire wall coming into the lower esses. I have had GMT working on the header, rocker and A-arm, and have paid a massive amount for an abysmal paint job on my spare tail, but I am wondering what else I should check. There is a small bend in the suspension pickup bar across the lower Hewland ears, the inner CV joint feels good [the outer CV was broken and I have bought a new one] and I see no visible cracks in the suspension pickup points or the wheel. As I fortunately don't have much experience in repairing crash damage, I am left with guess work as to how far to go. Someone in another thread had a much more significant crash, and was talking of an engine teardown to check the crank. Is that common / likely / usual?
    As always, any advice will be appreciated
    Swift DB-1
    South Carolina
    Liked: 673
    another view
    Swift DB-1
    Liked: 703
    I would replace the half-shafts if you haven't already. They may look fine but will likely break at some inopportune point in the near future.
    www.gyrodynamics.net
    OUCH. Mike is right. Doug at Fast Forward IIRC makes them out of really good material at a good price. I owuld disassemble hte CV and make absolutely certain it is not damaged.
    NW Colorado
    Liked: 30
    Quote Originally Posted by swiftdrivr View Post
    another view
    Is that a rust spot between 10:00 & 11:00 position?
    Dye pen the other side???
    John Mihalich, Jr.
    South Carolina
    Liked: 673
    GMT sent back the pieces after they repaired the rocker, and it looks like there is a tiny bit of rust on the other [matching?] side, but it looks very superficial. I'll look closer when I get back to good light and magnification.
    Thanks for the ideas. I'll talk to Doug Monday
    Swift DB-1
    Liked: 3280
    Obviously, if you want to be absolutely safe, you should replace the half-shafts, but...
    I've been using the same half-shafts for many years, and they've been through several wrecks that damaged the CV's, etc. It's my opinion that if you very closely inspect the shafts for any deformation (bending) and cracks in the snap-ring groove areas (use dye crack check kit) and find no signs of damage you can safely re-use them. YMMV
    Santa Rosa, CA
    Liked: 268
    Default crash damage
    I would replace the other CV joint regardless if it looks good. The cage is made of really hard material and any major impact without any visible damage can crack it. From experience...... The guys at SwayAway mentioned to me they have seen CV joints break even dropping them on the concrete garage floor as they are hard and brittle. Axles are pretty tough and are designed to absorb shock.
    Liked: 3280
    Quote Originally Posted by Jerry Kehoe View Post
    Yeah - I have had cages break, and most of them ARE brittle. Back when shops like Taylor Race Engineering were making high quality CV replacements, the cages were tough in add'n to being hard, and they would survive impacts. Most generic commercial versions of CV cages are of unknown toughness.
  14. #11
    Senior Member ejsprint30's Avatar
    Ohio
    Liked: 76
    These parts sound like perfect candidates for cryo treatment
  15. #12
    Danbury, CT.
    Liked: 1898
    Quote Originally Posted by ejsprint30 View Post
    Yea baby !
  16. #13
    Santa Rosa, CA
    Liked: 268
    Default CV joints
    I think SwayAway told me they actually re-heat treated the joint to soften it a bit to make it tougher and God knows the stuff they made was for off road racing and I can't imagine a worst case!
  17. #14
    South Carolina
    Liked: 673
    Fortunately, I bought 2 CV joints from Doug!
    Swift DB-1
