Thread: Backing plates
    villa park, illinois
    Liked: 91
    Default Backing plates
    What is the best and easiest way to check if backing plates are bent? Make a lathe adapter out of an axle retainer and measure runout seems to be the most accurate but tedious. Taking one off the car, place in a drum and measure height?
    One you determine how non-flat it is, how do you straighten them?
    I don't see availability of new backing plates (rear) online.
    Keep in mind disc brakes are not an option in a vintage applications.
    Duncannon, PA
    Liked: 299
    If they don't look straight then remove from the car and lay on a flat surface. I haven't tried to straight any but I am sure it could be done and gotten close.
    Ed
    Lakeside
    Liked: 58
    Brian:
    I have always looked at the space ( distance) between the backing plate and the drum. You can use a screwdriver to pry between the backing plate and the drum for minor bends.
    As for new, SoCal Imports has "rebuilt" units. There are new out there- (probably Chinese) but they are mostly for 68 upward- which is not an issue except for the two adjuster holes in the backing plate.
    Hope this helps.
    Dietmar
    Quixote Racing
