For those of you using a Schrader valve setup to be able to provide a fuel sample, do you use a tire-size Schrader valve or a different size? If a tire size, how do you depress the core to release the fuel, without making a fuel mess?
I use a valve from a GM fuel rail, not cheap but rated to handle fuel. Use the hose from the fuel pressure gauge used to check the pressure from the valve with the gauge removed.
Of course no one has ever asked me for a fuel sample.
This is seemed like the best option to me since a 1/4" hose is easily attached if a sample is ever needed. https://www.pegasusautoracing.com/pr...asp?RecID=3447
...on my Zetec fuel rail:
https://www.pegasusautoracing.com/pr...asp?RecID=7366
That could also be used for pressurizing accumulators or shocks.
With this, one caps the tire-sized Schrader valve with a metal cap when not sampling fuel, so no chance of accidental leakage.
I use a Jiffy-tite socket fitting in a T fitting in the fuel line. Jiffy-tite Quick-Connect Self-Sealing Fluid Fittings | Pegasus Auto Racing Supplies
With a matching jiffy-tite plug in a clear hose, I could use it for a fuel sample but I do use it to drain the fuel cell after a session.
Craig Farr
Stohr WF1 P2
So that the Stewards could play with their new fuel testers years ago when the rules were first written.....at random they flagged in every fifth car coming in at the end of a session.....well I was one of those flagged. I was told I was not going to get in any trouble no matter what they found because they simply wanted to gain knowledge of the testing process....but they wanted a sample right then and there. I refused saying there was no way I was going to break open a fuel line on a hot car even though there was someone standing there with a fire extinguisher. I think they were a little surprised by that but they did not press the issue. We all agreed to let the car sit and cool right there at impound until I was ready.......a half hour later I let them have their fun but I insisted also that I was the one to open the port while they watched me collect their sample. No problem.
Ever since the only deal with a fuel port is someone asking to see it during the Annual Tech Inspection and maybe one rare time to show it to an Inspector at impound at the end of a SARRC race as one of the random things they check. I've never been asked for a fuel sample since, never seen anyone else asked nor seen anyone protest someone else about fuel such that then a sample was taken.
I agree with farrout48 who said
"I use a Jiffy-tite socket fitting in a T fitting in the fuel line. Jiffy-tite Quick-Connect Self-Sealing Fluid Fittings | Pegasus Auto Racing Supplies
With a matching jiffy-tite plug in a clear hose, I could use it for a fuel sample but I do use it to drain the fuel cell after a session."
I use Jiffy-tite 31406 and 32406. They are dash 6 male fittings so you also need -6 to 5/16" fuel hose fittings. I do not use a T fitting, just put them in line (see below for why).
They are a dry break so no fuel gets sprayed around, even if hot. Buy the female fitting for the exit from the fuel pump and then put the male onto the line going to the carb. Buy a second male fitting and attach to a length of fuel line that can go into a bottle for fuel checks (or for emptying the tank etc).
If you want to check fuel bowl levels, you should ideally run the motor and then disconnect the fuel line before taking the top off the carb. With a dry break, you simply break the line. Too simple.
Maybe it's my compulsive nature, but I would not be confident in using any spring-loaded fitting for a fuel-sampling port, any more than I would rely only on the spring-loaded valve core to not slowly leak air on a tire, either on my racecar or street vehicles. I know they are "usually" reliable, but they do occasionally leak.
I always run valve caps on my race tires during a race for that reason. During practice or qualifying, I leave them off for quicker tire pressure checks, but during a race I want absolutely no chance of leakage.
The same goes for my comment on the sampling port. So I think a fitting with a positive seal similar to what I use on my racecar is safer with much less chance of any fuel leakage.
I used a -6 cap on a port on the bottom of the fuel pressure regulator.
Rules allow you to provide your own tool to open the port
I use the linked Pegasus fitting, screwed into a tee where my fuel pressure sender is. I have had to use it - at the Runoffs, of course. Though I've seen the FE guys getting tapped all the time to pee in a cup at regular Majors, even - joys of being in a spec class!
