Well my first vee race with my Mysterian at Mid Ohio is in the books and it was a mixed bag. One of the most interesting parts of the weekend was making major changes to the rear camber on the car. Full disclosure, I had NEVER driven a vee before this weekend.
My first two practice sessions were pretty exciting as the car was very loose in the rear. Every corner was a catch the car situation with a nice gentle spin into the mud in the carousel.
In the afternoon I was asking for some advice and one very knowledgeable guy looked at the rear of the car and said I had too much rear camber. We measured it at -9 degrees total with me in the car. We measured it at droop but I don't remember the number. There was a lot of travel in the rear and it felt soft.
Before I knew it I had three very nice guys helping me adjust it to -5 degrees total loaded and -2 degrees on the droop. We also adjusted the rear shock compression and rebound. The resulting changes also raised the rear ride height. The travel was more limited and the rear felt stiffer.
I went out for quali the next day and it was a different car! I was able to lean on it in the corners and I started dropping lap times.
Now I am trying to understand what happened? What is my lesson other than these settings are better? It certainly is possible that there was improvement in the squishy bit behind the wheel but it seems that the setup changes had a major effect.
I would love to have enough time to dial these settings in independently to understand their individual effects but that is unlikely.
Is there any common wisdom on the range for rear camber settings and how it effects the handling?
Nate
