This is a tool I made to simplify setting up suspension, steering and pushrod arm lengths. The posts are stepped at 1/2", 3/8" and 1/4". The left post is fixed in place, and the right one is adjustable and locks into place via the cap screw at the top. The slip fit cones allow for accurate measurements. The spacer and 5/8" sleeve are for the lower outer a-arm 5/8" I.D. spherical bearing. This tool makes it a snap to transfer exactly the settings from one arm to a spare. It is 32" long. I also have a set of 5/16" cones for those sized rod ends.
