Results 1 to 8 of 8
    Santa Rosa, CA
    Liked: 268
    Default Remote starter switch for changing gears
    For any of you who have struggled from time to time installing the back half of the gearbox to the main case when changing gears this little item makes life a lot easier. It's a remote starter switch that you can use with your knee to bump the motor over to match the splines to make it a lot quicker and easier to secure that last bit when inserting the gear pack. This way you have both hands and you don't need to con your wife to hit the starter button to bump the motor over. Takes only a few minutes to create! Pretty self explanatory.
    Destin FL
    Liked: 648
    Brilliant
    V/r
    Iverson
    Peninsula, Ohio
    Liked: 108
    Default Starter
    My FSV has a remote starter in the engine bay. Also brilliant .
    both seems like one of those lightbulb moments!
    Liked: 3318
    Must be easier on a Staffs box. I get the gear section in to the point where the splines would begin to engage and then with the bottom nut on (which it is before I install the gear section), I just turn the nut until the splines line up.
    Vancouver BC
    Liked: 471
    I was going to say just the same thing about an LD200.
    mukwonago, wisconsin
    Liked: 96
    Quote Originally Posted by alangbaker View Post
    I just spin the rear wheels.
    john f
  9. The following 3 users liked this post:
    Tempe, AZ
    I like to have the car on the ground, so I can spin the wheels with just a little push back and forth while holding forward pressure.
    I just finished the easiest change I've ever done, and want to thank whoever it was on ApexSpeed that suggested a piece of string to keep first gear from falling off its hub while I'm jiggling things onto the pinion shaft. But I don't recall who it was...
    Edit: I guess that's just a trick for the LD200. I don't think it would keep the reverse gear in a MK box from falling out of its fork over and over again...
    Caldwell D9B - Sold
    Member EVT's Avatar
    Oregon
    Default starter assist gear change
    I place a bungee strap across the rear case then hit the starter button. The bungee pulls the case forward every time with no hands. EVT
    Fast Eddie
