A question about bolt torque. There are some good threads on Apexspeed about this topic but I have a different twist to the question. In re-assembling some wheels the manufacturer stated in a personal email to me that a torque spec of 18 Nm should be used (159 in-lbs). The 6 mm x 1.0 bolts to be used were purchased from McMaster-Carr and are rated as Class 10.9. A search of the many sources of specifications show such bolts to have a max torque value that ranges between 14 to 16 Nm (124 to 142 in-lbs).
Seems to me that despite this particular wheel manufacturer’s recommendations, a bolt's maximum rated value for torque should not be exceeded.
Thoughts?
