Results 1 to 5 of 5
    Albany, NY
    Liked: 235
    Default Bolt Torque and Wheels
    A question about bolt torque. There are some good threads on Apexspeed about this topic but I have a different twist to the question. In re-assembling some wheels the manufacturer stated in a personal email to me that a torque spec of 18 Nm should be used (159 in-lbs). The 6 mm x 1.0 bolts to be used were purchased from McMaster-Carr and are rated as Class 10.9. A search of the many sources of specifications show such bolts to have a max torque value that ranges between 14 to 16 Nm (124 to 142 in-lbs).
    Seems to me that despite this particular wheel manufacturer’s recommendations, a bolt's maximum rated value for torque should not be exceeded.
    Thoughts?
    Liked: 3280
    Thoughts?
    Without any other information, it appears that you are correct. The only thing that "might" require more torque than the bolts are rated for would be a large amount of friction to overcome because of some unusual locking nut type or some other strange condition.
    Liked: 139
    Were the OEM bolts class12.9 ?
    Liked: 3280
    I'll bet you're correct.
    Albany, NY
    Liked: 235
    Just this minute the manufacturer responded to my follow up email. Yes, uou are right. They had 12.9 as OE.
    Thanks!
