Results 1 to 6 of 6
    Default Brake balance Adjuster
    I have a Tilton type balance bar in my car. The adjustment appears to be "sticky". I am assuming that this is from crud in the tube. I also am assuming that the only effective way to clean it is to take the pedal loose from the floor, unscrew the M/C push rods and then disassemble, being careful to measure everything so when it is put back together, ii is not all out of whack?
    Right?
    Mississauga, Ontario
    Liked: 902
    Default yes, and....
    Clean and lube the cable. And check to see that the stickiness is not a result of the bend in the cable having too tight a radius.
    cheers
    BT
    Liked: 3317
    Right?
    I clean mine every year - part of the winter maintenance.
    Destin FL
    Liked: 647
    Dave, have a winter maintenance CL you would like to share
    V/r
    Iverson
    Liked: 3317
    Dave, have a winter maintenance CL you would like to share?
    I didn't have a list per se, but I made one up from some of my past winters' work lists and it's now posted.
    Here's a link to my thread with the checklist: https://www.apexspeed.com/forums/sho...ntenance)-List
  9. #6
    Thanks everyone.
