    Member wjpierce's Avatar
    Liked: 16
    Default Brabham BT41 cockpit/ monocoque question
    Hello again,
    Question: Looking down into the cockpit of a Brabham BT41 there are walls defining the width of the space. My question is; Are this walls part of the monocoque and therefore structural or are they there to define the cockpit width only. In pictures, I am struck by the small number of visible rivets leading me to wonder if these walls are load bearing. If not, can these walls be widened to accommodate a larger driver? I hope I am being clear. My knowledge of monocoque chassis is less than negligible. Thanks everybody. Looking forward to your thoughts. Bill Pierce
    Mokena IL.
    Liked: 59
    Try Marc Bahner Engineering, I guess they have repaired one over time.
    http://www.bahnerengineering.com/
    Sacramento, California
    Liked: 23
    Quote Originally Posted by wjpierce View Post
    Hello again,
    Bill: The walls are load bearing. Do not cut.. You will be cutting into the fuel bags. A larger driver can be accomodated by removing the fiberglas seat (if it has one).
    Liked: 292
    Default use
    a hammer?
    Liked: 1262
    Quote Originally Posted by Thomas Wirtz View Post
    Bill,
    He's in Newberry Park just off the 101. Probably has pictures and ideas...
    Hartford CT
    Bill,
    As I recall, unlike the BT-40, the 41 had steel inner tub walls in order to make F3 minimum weight of the time, so there might be some welding/brazing where you would expect to see rivets.
    Kempsey, UK
    Default Extra girth room.
    Cut a rectangular hole in each side, maybe 8" x 4" just about where your hips are and let in a joggled panel secured with rivets. As mentioned remove the fuel cells first!
    I have seen several cars modified like this to accommodate the well fed driver with a broader beam.
