Results 1 to 18 of 18
    Destin FL
    Liked: 645
    Default .PDF Drawing Converted to .AI or .EPS
    Gents;
    I have a Solidworks drawing that was saved as a .pdf. Anyone know of a process to convert this .pdf to an .AI or .EPS drawing?
    V/r
    Iverson
    Liked: 1871
    I don't believe that you can do it directly is SW, but there are plenty of converters you can use, like this one:
    https://cloudconvert.com/pdf-to-eps
    No idea about the quality of the conversion, or what you can do to edit it afterwards.
    Member tsiembieda's Avatar
    Waukee, IA
    Default PDF converted to .AI or .EPS
    I used to convert pdf to .ai and .eps files when I worked for a commercial printer. I would open the pdf in Adobe Illustrator then save it as a .ai or .eps file. I have an older version of Illustrator and might be able to convert it for you if you want me to try.
    Contributing Member phantomjock's Avatar
    Red Neck Riveria, FWB, FL
    Liked: 105
    Hey Rick -
    Thought I might have something on my CAD-Drive, but no soap. But, I found 2 sites that will do it online for free - but don't know if they're "secure" or if that is important.
    https://pdf.iskysoft.com/pdf-tips/co...pdf-to-ai.html
    and,
    https://www.freeconvert.com/pdf-to-eps
    Mind you - I've not tried either, but at free might be worth a go.
    Cheers - Jim
    Destin FL
    Liked: 645
    Tony, I would be grateful. I'll PM you the .pdf if you need it
    Quote Originally Posted by tsiembieda View Post
    V/r
    Iverson
    Vancouver BC
    Liked: 470
    Gents;
    Rick, assuming you need to have an .ai file (or .eps) for use in Illustrator, you should know that modern versions of Illustrator can open PDF files directly.
    What's the plan?
    Destin FL
    Liked: 645
    Quote Originally Posted by alangbaker View Post
    What's the plan?
    Alan;
    The plan is to have five (5) Stack dash plates LASER cut if I can get a vector drawing of the .pdf /.jpeg I enclosed.
    V/r
    Iverson
    Liked: 703
    Rick,
    My old version of Photoshop will save a .pdf as an .eps, if that is what you're looking for.
    On the other hand, the laser shops I work with can use a .dwg or .dxf, which would be easy to create from SW or from scratch, given the detailed image you posted.
    www.gyrodynamics.net
    Destin FL
    Liked: 645
    Mike;
    On the advice from a gent on Apex, I am looking at a business that runs small orders quite reasonable. But the manager replied to me today with this:
    "Do you have a "vector-based" version of your design that we could use? We will need the art to be in a format such as Adobe Illustrator .ai, or .eps."
    Rick,
    V/r
    Iverson
    Olympia, Washington
    Liked: 536
    As simple as the blueprint is, you could probably recreate it in LibreCAD as easily as going through the various conversions. Raster graphics to vector graphics can be kind of nasty, unless the past few years have come up with better converters.
    Liked: 1871
    Alan;
    If that is all, just redraw it and save as a .DXF. Whomever is doing the lasercutting should be able to use as-is oe convert it themselves.
    Waukee, IA
    You can pm me and I'll see what I can do with the pdf.
    Destin FL
    Liked: 645
    Default .pdf file
    Hope this works
    V/r
    Iverson
    Waukee, IA
    I have the pdf converted to both .ai and .eps files. I cannot attach them to the thread because they are not a supported file format.
    Can you pm me your email address and I can send them to you.
  17. #15
    Destin FL
    Liked: 645
    msengineering at cox. Net
    V/r
    Iverson
  18. #16
    Waukee, IA
    Thank you, files have been emailed.
  20. #17
    Olympia, Washington
    Liked: 536
    Can the shops work with a bitmapped image or do they require an actual vector file such as in a CAD package?
  21. #18
    Liked: 1108
    If these need to be dead accurately cut, any “conversion” of this from .pdf to .ai will have compromises — the question is with the significance of some deviation (talking a few thousandths here).
    “Auto-Trace” is hack, and will always be hack. It was created for those insisting it’s their only choice when it’s absolutely not and has been a source of angst for anyone having to clean it up afterwards.
    Opening a pdf in Illustrator will not get you the “cutting path” you need for this to be in proper vector art. Think of the “path” in the same terms as the software would need if it were to cut out vinyl graphics.
    I’ve done a ton of work in Illustrator since ‘88, and despite knowing I could trace this very closely, by hand and in layers, and likely within working tolerances, I recommend you send what you have (the above art) to the company cutting it out and let them decide exactly what tolerances are needed.
    Asking on a forum is asking for parts that don’t fit. Just saying — and mean no offense in saying that.
    I’d be happy to recreate this correctly, at N/C, but don’t want to waste a minute on it if someone else is already doing it.
