Results 1 to 5 of 5
    Senior Member Bob Coury's Avatar
    Jupiter, Florida
    Liked: 79
    Default Head Surround Foam Survey
    What are you all packing your carbon fiber head surrounds with?
    Bob
    Liked: 1403
    I think the head surround should be a fiberglass or Kevlar piece. Carbon fiber in a crash is like a bunch of razor blades flying around. Don't ask how I know this.
    I would use the same materials that you use to make a bead seat.
    NY
    Liked: 127
    I made mine from the excess from my Bead Seat. Wrapped them in Nomex and they came out great.
    Will Velkoff
    Van Diemen RF00 / Honda FF
    SoCal
    Liked: 102
    When helmet collars first appeared in the late '90s, they were padded with multiple layers of Confor foam. Each layer had a different density and stiffness. However, the temperature sensitivity of Confor significantly reduced its impact performance when hot.
    The current requirement in the top-level series is rigid foam covered with Kevlar or some other high toughness fiber, in a resin with a low coefficient of friction. It is better for the helmet to be able to slide along the surface during an impact.
    The big downside to rigid foam is one-time use, while Confor is largely unaffected by impact.
    Pittsboro IN
    Liked: 281
    Our FIA Formula E head surrounds are Kevlar filled with Confor, same as in F1.
    F1 does require either pink or blue Confor depending on the ambient temp
