    West Union, IL USA
    Liked: 319
    Default 45 DCOE question
    Plastic or brass floats for original Italian Weber 45 DCOEs? (The brass floats appear to be just fine, but I have seen references on line to the plastic ones being superior. Can't figure out why?)
    Thanks in advance for your thoughts!
    Sydney, Australia
    Default Dcoe Floats.
    Brass floats in orig Old school series Dcoe’s. The later 151 and 152 series with the additional air bleed screws run the plastic floats.I have used complete float assy’s swapped between early and late series dcoe bodies with no ill effects.
    Liked: 1486
    from what I've seen the floats don't break off the plastic ones if you forget to fill the bowl before a long tow
    Destin FL
    Liked: 645
    Curious, but are the IDA and DCOE brass floats the same? I have some NOS IDA brass floats available.
    V/r
    Sydney, Australia
    Default Ida/Dcoe Floats
    Curious, but are the IDA and DCOE brass floats the same? I have some NOS IDA brass clots available.
    They are quite different. Dcoe are a twin float design and the Ida are a single larger dia float design. I am sure some one will have a use for them.
    Tacoma, WA
    Liked: 323
    IDA/IDFs are different than DCOEs.... I could be interested in the IDF ones if you decide to sell.
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Destin FL
    Liked: 645
    These are NOS. I'll do $25.00 each shipped to you, CONUS.
    V/r
