Results 1 to 9 of 9
Thread: Battery
    Senior Member Garry Sharp's Avatar
    Dahlonega, Ga.
    Liked: 118
    Default Battery
    Can anybody suggest a battery for the Vee I'm putting together? Is anybody using Lithium?
    Garry
    Olympia, Washington
    Liked: 536
    Quote Originally Posted by Garry Sharp View Post
    Only to control my depression about no racing
    Dahlonega, Ga.
    Liked: 118
    Quote Originally Posted by Bardahl77 View Post
    I'm glad you found something that works for you. Now back to that battery thing...............
    Olympia, Washington
    Liked: 536
    When I was working tech, I saw formula cars with brands like Shoreai, AntiGravity and Braille, as I recall. They all seemed to work OK.
    alabama
    Liked: 148
    Most folks in Challenge Cup Series use agm or Gel Cell.
    14-20 Amp batteries seem to work fine.
    Although the lithium are light they need to monitored while
    charging and are expensive.
    Liked: 58
    Garry
    I just bought this on the recommendation of another vee driver:
    https://www.amazon.com/Shorai-Lithiu...+lfx21&sr=8-13
    If weight is not an issue (12lbs vs 3lbs), I have been using this for a couple years:
    https://www.amazon.com/Mighty-Max-Ba...=12v+18&sr=8-1
    With lithium you want Lifepo4, not lithium ion. They can be charged normally too just be mindful not to over charge them. But you do need to balance the cells occasionally to ensure longevity which does require a special charger. You also can't trickle/float charge them with normal chargers... i believe.
    1993 Citation FV
    NEFV - 2022 Champion
    NERRC - 2022 Champion
    NC
    Liked: 303
    The "special chargers" while not required are also not that expensive. I see no reason why anyone wants a big heavy battery when small light ones are available.
    https://antigravitybatteries.com/pro...me-power/sc-1/
    Olympia, Washington
    Liked: 536
    I notice a lot of the lithium batteries mention they're not intended for "total loss" systems without alternators. Do you need to be careful about discharge levels?
    Liked: 290
    Not uncommon for lithium cells to have built in protection on the low side.
    Is the output of the alternator correct for a lithium battery max voltage (Lifepo4) of 12.6v/3cell or 16.8/4cell groupings?
