I'm looking for the bell housing bolt pattern for a Toyota 4AGE engine.
I'm making an adaptor plate to a Hewland Mk 9 gearbox.
Any help would be appreciated.
Should be easy to pick up a front wheel drive 4age box and use the bell housing for your template. I have given them away in the past only requiring the engines.
https://www.gumtree.com.au/s-ad/dian...box/1254023208
http://www.ae86drivingclub.com.au/
https://www.rollaclub.com/board/?ct=1598865597
I have a 4AGE in my Lotus 7. I also have a spare gearbox with bell housing. If you have no other sources I can make a paper template and mail it to you if need be. IM if you like.
Graham
Transferring bolt pattern as above is fine, however most important to get centerline of crank right...same for alignment sleeves/pins.
Don't assume.....think/plan it out, confirm, before cutting metal.
Bob L.
