Thread: Drop Spindles?
    New Hampshire
    Default Drop Spindles?
    Is it common for Vee's to run drop spindles or is it more typical for guys to run stock spindles and lower the height/adjust with shims?
    Lakeside
    Liked: 58
    Default Spindles
    From the GCR:...no other modification of the wheel spindle is permitted.
    Further: non VW replacement spindles shall maintain the same geometric relationship between the spindle and the king pin bore and boss.
    Dietmar
    QuixoteRacing.com
    New Hampshire
    Quote Originally Posted by Dietmar View Post
    Dietmar
    QuixoteRacing.com
    Thanks for the info!
    near Athens, GA
    Liked: 837
    For adjusting ride height, beam 'adjusters' are now allowed in SCCA FV... If you are, perhaps, planning to do VINTAGE racing, the various groups have different rules, but in the early days, ride height was adjusted by BENDING the spring packs inside the beam... using LONG bars and the 'turkey leg' itself to perform that function. I don't have it at my fingertips right now, but there IS a youtube video that shows someone performing that 'adjustment' on a formula vee .. but I can't seem to find it right now.
    If you use a ride height adjuster, Mike Hinkle has made a youtube video of 'how to' that you might find informative.
    https://www.youtube.com/watch?v=7qoa4_eldjw
    Hope this helps...
    New Hampshire
    Quote Originally Posted by Steve Davis View Post
    Hope this helps...
    Mike actually sold me my car! I'm sure it could help. Thank you.
    Torrington CT
    Liked: 480
    Here you go:
    Bending springs
    https://www.youtube.com/watch?v=BNhQkxL29Fk&t=87s
    ChrisZ
    near Athens, GA
    Liked: 837
    Here you go:
    Yep.. that's it. Just kept using the wrong search terms .
