Gents;
It is that time to get my chassis stripped, have some tidbits welded on, then re-powder coated.
I have read stories here of heat warpage when dry media (e.g., 30/60 garnet) is used to remove powder coat, and I am definitely not a candidate for that.
I called a local dry media blasting company to get some technical details, and I am supremely confident this is not the way to go. He gave me the company’s where he purchases his media (Cesco, 843.760.3000), and I talked with one of their technical support people in Tim.
After explaining the details of what I was doing, and the necessity to reduce as much heat as possible, he recommended “Dustless Blasting’. Although he did recommend using an abrasive under low power to “profile” the chassis surface for better coating adhesion, dustless was the best approach.
I called a company in Enterprise Alabama, and he explained dry media applies 100F above ambient temperature. Dustless blasting is a process where water is introduced into the media pressure hose or nozzle, and substrate temperatures are 10F BELOW ambient.
Anyone familiar with this method? Thoughts?
