    Destin FL
    Liked: 645
    Default Weldable Dzus Female Fasteners
    Gents;
    I would consider (read: prefer) welding female high-end Dzus type receptors into my chassis lower sides to facilitate coachwork removal. Suggestions?
    V/r
    Iverson
    Liked: 854
    These?
    If so, how many?
    Sent from my SM-N960U using Tapatalk
    Liked: 1261
    I bought these for a tin top fuel tank cover project
    https://www.summitracing.com/parts/sum-g1618
    Destin FL
    Liked: 645
    I was thinking a socket type that would be inserted into the frame rail and welded flush with the rail.
    V/r
    Iverson
    Senior Member Gary_T's Avatar
    Regina, Sk. Canada
    Liked: 106
    How would the backing spring be attached in a socket recessed into a frame rail?
    The tabs above are what I've used - very easy, the tab part is long enough to bend/cut to fit just about anywhere you require.
    Gary Tholl
    #24 BlurredVisionRacing
    Liked: 1261
    I used nutserts with floating nuts. Really worked well.
    https://www.mcmaster.com/93669A220
    Using dzus in a closed frame rail - not sure how.
