    Destin FL
    Liked: 645
    Default Steering Wheel Electrical Switch Coupler
    Gents;
    I have a Stack ST8100 for my car, and it comes with four (4) function switches. Then there is the PTT switch.
    In my prior life, I fabricated a dash mounted four (4) pin PPT micro cannon female plug mount, so I could easily remove the steering wheel completely to get in and out of the car.
    My steer wheel quick disconnect is of the “zero slop” type. I was wondering if anyone has fabricated, seen, or know of any enterprise that has a multi-pin male/female cannon plug steering shaft bracket assembly?
    V/r
    Iverson
    My 2004 PFM had a quick disconnect in the hub. The steering wheel had 4 momentary push buttons. Spa makes them. Pegasus stocks p/n 3407 (8-pin 5/8” shaft) or 3419-026 (12 pin 1.0” shaft)
    Pittsboro IN
    Liked: 278
    The electrical plugs themselves are Lemo in the SPA units if I am not mistaken
    Paso Robles, CA
    Liked: 285
    I've wired & repaired both the SPA and Krontec units. The Krontec uses Deutsch Autosport connectors (modified but the tools to work on it are common).
    If you want to use your existing quickrelease, looking at what Krontec did might give you some clues.
    Fred is correct, Lemo pins/housings are used in the SPA -- but they install them is special pre-wired pieces. Parts are available to repair both the wheel and shaft side.
    Here is someone selling the Krontec:
    https://racespeconline.com/products/...14331353595947
    and the SPA:
    https://www.spatechnique.com/store/i...ID=760&catID=9
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
