ELDEN PH8 FORMULA FORD FOR SALE---$20,500
I'm selling my Elden PH8. The car is located in Longmont, Colorado.
Photos can be seen here: https://photos.app.goo.gl/Gjk3ixUm1JDS6iE3A
My father passed away and left me his Titan Mk6 and a sports racer. I built this car to be my own and therefore went the extra mile in many respects. Unfortunately, having three race cars is simply one car too many, so this one has to go. Iām sure I have forgotten to include something. Please feel free to reach out with any questions!
Aside from stripping and refinishing the chassis, the car has more or less had a full restoration. My intention was to race it for a season or two to sort out any issues, then strip the car to repaint the chassis. I just never got to it; I was having too much fun driving the car! The suspension has been completely rebuilt using Aurora PTFE rod-ends. New 2ā Spax shocks were installed along with D Faulkner springs. Uprights were rebuilt with new bearings. A new wiring harness was made and all new Smiths gauges were installed. A new dash panel was made and installed. The engine has approximately 8 weekends on it since rebuild. The cylinder head was freshened two race weekends ago. The gearbox has about ten weekends. I had the gear cluster out before the cars last race weekend and the dogs are nice and sharp. I fabricated a new oil reservoir, as the original was in very poor condition. I also made up a new fuel cell can and had Fuel Safe make a new bladder in 2017. Master cylinders are new and calipers have been rebuilt with stainless pistons. The engine cover is included with the sale. It has been painted and mounts to existing dzus tabs at the roll bar, but has no mounting points at the rear of the car. The rear anti-roll-bar was damaged during a testing day incident years ago. It is included, but not mounted to the car due to damage. The original seat is included, but would require the battery to be relocated to be used. The following is a list of what I have restored/replaced/modified on the car. Restored means fully disassembled, cleaned, paint stripped via chemical stripping or bead blasting, priming/painting, or plating, reassembly with new consumable components (rod-ends, bearings, fittings, hardware, etc), finally adjustment and testing. The car is being sold with an RMVR logbook.
Replaced master cylinders
Restored pedal cluster
Added removable panel in front of master cylinders to check fluid without removing bodywork.
Restored steering rack (including rebushing housing)
Replace steering column (eliminating rag joint also)
New steering wheel and quick release hub
New dash panel
New Smiths gauges
New mil-spec toggle switches
New wiring harness
New battery and battery hold down
Restore and optimize shift linkage(new apex joints installed, new shift lever/mechanism machined and installed)
New fuel cell can fabricated and new fuel cell bladder made by Fuel Safe (2017)
New oil reservoir with sight glass--no more tape measure level-check
New, Ivey modified carburetor
New 123Ignition distributor--can revert to Lucas unit if desired
New coolant hardline and flex hoses
New catch can mounting bracket and cans
New motor mount and gearbox mounting bushings
New Volvo/BMW type driveshaft flex discs
New u-joints
New LED rain light
All four uprights rebuilt with new bearings
Suspension rebuilt with new Aurora PTFE rod-ends
New Spax CSX 2.0ā shocks (zero-droop front)
New D Faulkner springs (250lbs front, 200lbs rear)
Proper flat-floor alignment
Brake rotors turned
New wheel studs installed
New stainless sleeve nuts
Calipers rebuilt with stainless pistons and Hawk black brake pads
New stainless brake flex lines
New oil and water plumbing
Fab new coolant header tank with bleeds from radiator and thermostat
Install new coolant hardlines
New paint on body work
Gear ratios currently installed:
19:32
22:28
24:28
25:27
