Additionally, the mounting bolt spacing is wider in the front than the rear.
So, knowing that my rotors are both 1.0" wide, and the pads are the same thickness front and rear, that means the front caliper pistons are extended an average of 0.05" further each side of the rotor than in the rear. Whether or not this matters, probably not.
But I then proceeded to more carefully inspect the brake rotors front and rear. While they are both the same width and diameter, the fronts are actually offset by 0.10" on their mounting tabs. The eight mounting tabs are the same thickness as on the rear (0.25"), so I believe the front rotors were custom made by cutting a 1.2" rotor down to 1.0", removing 0.1" from each side while not removing any material from the eight mounting tabs for the hat.
Given the caliper width differences, my previous goal of reducing rotor part count to two (using identical rotors front and rear on each side), cannot be done unless I have new rotor hats made for the front which create the proper rotor offset for a 1.0" rotor.
I think instead, going forward, I will make use of the extra width of the caliper by having a 1.2" wide rotor cut down to 1.1", removing 0.05" from each side and leaving the mounting tabs sticking up 0.05" also. Then the caliper pistons will be saved that extra 0.05" movement each side mentioned earlier.
So aside from all this, I also noticed that AP calipers left to right are mirror images of each other. Not sure why they didn't make them fully symmetrical so that you could simply rotate it 180 degrees to mount from left to right. Maybe you can anyway. The only difference I can discern is the larger of the pistons are on the bottom in the rear, both sides. So if you rotated it 180 degrees one side would have the larger of the pistons on top.
Coincidentally, the front calipers, also mirror images of each other, have the larger piston on top, both sides. Strange!
If I was designing the uprights from scratch, I'd make the caliper mounts the same dimension and use the same caliper part number for all 4 corners. With fluid parts on all 4 corners of each caliper and behind both pistons, you'd simply have to switch the cross-over tube to the bottom position for each corner and the brake line to the lower backside piston for each orientation of each corner.
I digress, I will resign to buying 4 unique rotors and am still hopeful that at least the brake pads might be able to be common all around.
Cheers,
Mikey
