Results 1 to 21 of 21
    St Cloud, Fl
    Liked: 136
    Default Next cleaning problem
    Anyone find anything that will remove the double sided tape from the wheel weights without 1) hours of elbow grease, 2) messing up the finish of the wheels or 3) stinking up the shop?
    John
    Knoxville,Tn
    Liked: 65
    Original manufacturer finish? Or painted with rattle can spray paint?
    Have you tried wax and grease remover, goofoff, or wd40 ? Those usually wont attack paint. The xylene based carb cleaner will remove adhesive and any greasy residue but also will remove spray paint. It usually will not remove original wheel finish but definitely will have an odor.
    Vacaville , California
    Liked: 77
    JR
    How about one of those decal adhesive remover wheels?
    https://www.ebay.com/i/283594734496?...yABEgIe6vD_BwE
    Contributing Member Jtovo's Avatar
    Chicago, IL
    Liked: 77
    I second this tool.
    Olympia, Washington
    Liked: 536
    Know any drag racers or RC plane/car folks? Nitromethane removes sticky stuff pretty well.
    Florida
    Liked: 14
    Regular rubber valve stem on drill works good and is safe on painted wheels or parts.
    Vancouver at heart but Adelaide is where you'll find me
    Liked: 15
    Default Clean
    buy a caramel wheel on ebay for use in your drill sometimes a bit of wax and grease remover too
    never damages anything and smells good too
    Arizona
    Liked: 323
    Use a screwdriver or scraper being very careful not to scratch paint and get the weights ripped off. Don't worry about the amount of foam and glue left over. Just get the weight off and out of the way. Roll the wheel so the left over foam and glue are at the bottom. Have some of this GooGone on hand and then spray the foam patch with a good bit of this stuff. If you can let it set for a few hours (or overnight), you will likely be able to wipe almost all foam and glue away with a rag. Or, I keep the light duty ScotchBrite pads in the shop and you may have to run over it a little with one of these.
    https://www.amazon.com/Goo-Gone-Orig.../dp/B00006IBNJ
    Liked: 97
    I have always just soaked them in WD40. /the soaking part is critical. Sounds like there are a lot of great ways to do this.
    Skip
    colorado
    Liked: 49
    I spray Tarminator Tar & Sap Remover and scrape the foam off using an old credit card or the plastic cap itself as a scraper.
    Senior Member Buc01's Avatar
    Moore, OK
    Liked: 73
    John
    I always use Goo Gone. Spray it then let it soak for a few minutes.
    Then use a plastic body filler type scraper. Usually comes off fairly easily.
    Aaron
    Moore, OK
    Liked: 73
    Default Remove Wheel Weights
    Quote Originally Posted by Fast Finn View Post
    Thank you for the tip! Will give it a try next time I mount some new tires (well.... new to me anyways )
    Aaron
    Muncie, Indiana
    Liked: 977
    Great ideas - I use prep-sol and it comes right off of my painted wheels.
  17. #15
    Moore, OK
    Liked: 73
    Default Cleaning Solvent
    This one John?
    Thank you, Aaron
  18. #16
    Liked: 909
    3M makes a "wheel" that is kind of rubbery that is used to remove the double sided tape that holds body side moldings on. I have used it on painted cars without damaging the paint one iota.
    https://shop.advanceautoparts.com/p/...E&gclsrc=aw.ds
  19. #17
    Liked: 290
    Soak/wet with WD-40.
    Wisconsin
    I use something like this on the daily at work. Removes wheel weight adhesive from all different types of wheel surfaces and finishes without any damage.
  21. #19
    Contributing Member sflaten's Avatar
    Minnesota
    Default adhesive remover
    3m makes a General Purpose Adhesive Remover that I picked up at NAPA. I have also used brake cleaner
  22. #20
    Santa Rosa, CA
    Liked: 268
    Default decal remover
    I have found plain old gas works just fine and seems to work on any kind of adhesive and guess what you always have that!
  23. #21
    Muncie, Indiana
    Liked: 977
    Quote Originally Posted by Buc01 View Post
    This one John?
    Thank you, Aaron
    I use one made by Pyroil, I imagine any brand would be fine.
