Results 1 to 20 of 20
    Ottawa,ON
    Liked: 138
    Default windshield / deflector thickness
    Hi I've been trying to make a wind deflector / windshield for my PFM.
    First one was doing great until I drilled a hole for a rivet and it cracked... not near the hole in a totally different place... frustrating.
    It wasn't bad so I used some packing tape to fix it, but decided to make another one.
    Anyways, second one was way worse, it cracked in 3 places when I was cutting it with the jigsaw. I have it clamped on a piece of plywood to avoid vibrations etc.
    Either I bought really crappy plexi, or maybe it's too thin? It's optix acrylic apparently about 3/32" thick
    Thoughts? Thicker material? Or maybe buy some lexan? DIdn't think a little piece like this was going to be a pain or need to be super strong.
    I used lexan on my PFM. Can’t recall thickness but was either 3/32 or 1/8”. Never had to replace it. I only attached it with 3M push lock strips.
    Mokena IL.
    Liked: 59
    Default Windscreen
    FWIW,
    I just had a new windscreen made by Aircraft Windshield in California for my 1978 Super Vee.
    The original was cracked when I bought the car and was 1/8 thick. Aircraft Windshield suggested I use the standard 3/16 thick material.
    A little thicker material couldn't hurt.
    http://www.aircraftwindshield.com/
    near Athens, GA
    Liked: 837
    I used a piece of flexible black abs plastic (~1/8"?) that I found lying around my shop. Trimmed it to about 2.5 inches wide and maybe 8 inches long (didn't measure .. just guessed ) Drilling it was easy since it was 'pliable' anyway. I put it in my vice lengthwise and bent ~half of it up, then slit the other side in 3 or 4 places so I could form an arc. Then held it on my cowl and marked it for drilling to hold it's shape against the wind. After installing, I mixed up some abs 'goo' and put some spots along the bent seam to stiffen it a bit. Seems to be working great after 4 races and a couple of test days.
    Ottawa,ON
    Liked: 138
    Mine certainly needs to be clear as I'm very low in the car.
    Ft. Myers, Florida
    Liked: 225
    Default Lexan
    When I had my FF I used clear 1/16” lexan. Cut with tin snips (the cheapo yellow-handled Wiss snips you can get at Home Depot). As I recall the edge was nice enough that minimal filing was required. I think the acrylic I found was too brittle.
    as the phrase goes, YMMV.
    John
    Last edited by JHerscher; 02.26.20 at 7:40 PM. Reason: Corrected thickness to 1/16”. Old age...
    Senior Member DK540's Avatar
    Virginia Beach, VA
    Liked: 83
    Default Lexan
    Gotta be Lexan.
    DK
    Ottawa,ON
    Liked: 138
    Sounds like lexan is key. Thanks
  13. #9
    Senior Member Nardi's Avatar
    Southeast
    Liked: 121
    Maybe modify an old face shield as a wind screen?
    Ottawa,ON
    Liked: 138
    Needs to be 16x5 inches.
    By the way, if you haven’t had one before make one that you can adjust the mounting height or make a couple in different heights. You will find a sweet spot that gets the air smoothly to the top of your helmet.
    San Jose, Ca
    Liked: 94
    If you have access to a sheet metal shear that will work too. I believe there is a different angle on drill bits made for drilling acrylic or lexan to minimize cracking.
  17. #13
    Ottawa,ON
    Liked: 138
    The drilling didn't crack it. Just holding it did. Very odd.
    It's also cold in my garage so possible the cold plastic was just too brittle.
  18. #14
    Burr Ridge, Illinois
    Liked: 301
    Always Lexan...NEVER Plexi (too brittle).
    I've used 1/16" (.062") Lexan for windscreens on FV's without fail.
    Unless there are specific rules for thickness, that would be my choice.
    Glenn
  19. #15
    Ottawa,ON
    Liked: 138
    Sounds like a plan. Will order a small piece, looks like I can get 2 windshields for $15 ish.
    Schellsburg, PA
    Liked: 115
    Quote Originally Posted by Jamesbe View Post
    Stevan Davis has super powers and can see through black ABS....
    BLS
  22. #17
    near Athens, GA
    Liked: 837
    It's a gift. :-)
  24. #18
    Lafayette INdiana
    Liked: 295
    If you wan to shape the plastic put it in the oven. At 300 degrees the plastic becomes like raw pizza dough. At that point you can put over a mold made from cardboard and when it cools off a bit it becomes rigid again. If you use a saw on it like a jigsaw you must not go too fast as it will get hot and gum things up.
    I made a rather elaborate front screen/fairing for my BMW about 40 years ago. It came out pretty well. I positioned it so I just looked over it. The air deflected over it and it was good in the rain too.
    On my Lotus D mod I made a deflector of aluminum, about 16" by about 4" and attached it with pop rivits. it was a bit crude but did the job. It deflected the air away from my face and I positioned it so I looked over it. ... perfect.
  25. #19
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 610
    Default Windscreen
    I use a small soldering iron and burn a hole though it for fasteners.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
  27. #20
    Woodstock, NY
    Liked: 81
    Lexan can also be bent in a brake to form flanges or tabs for mounting.
