    Destin FL
    Liked: 645
    Default Side Pod Floor Materials
    Gents;
    Although I did not use Jab-rock on my last rebuild, I found a reasonable facsimile that worked quite nicely. But I would like to move to an ABS or other workable (routers, saber saws ......) material. Any ideas?
    V/r
    Contributing Member phantomjock's Avatar
    Red Neck Riveria, FWB, FL
    Liked: 105
    Rick -
    I've looked for foamed PVC, it is available but not in our area - but might be a product to consider. Also, Speedway Motors sells a 0.11 thick plastic in rolls for roundy-round car body panels. Pretty cheap - like 20 bucks for 20 feet or so and nearly 2 ft wide. Fills the space if no structural safety issues in the pods?
    Call you Monday.
    Cheers - Jim
    When I used to fly Phantoms, I was called an AVIATOR.
    Now I race cars. So, am I now called a PAVIATOR?
    Liked: 1474
    I cut Jabroc with a regular old bandsaw with metal blade on it. No issues whatsoever.
    Liked: 1871
    Baltic birch plywood is also a good option. You can make it last a lot longer by vacuum bagging it with epoxy resin.
