Results 1 to 15 of 15
    Arizona
    Liked: 323
    Default Steering Wheel Sealer / Dip ?
    If you take a closed top steering wheel and cut the top center section out to make an open top wheel, what do you put on the section that has been cut? I have a steering wheel like this and want some kind of a 'rugged' dip to put over the ends. I have used a rubber type of tool dip in other applications, and I don't think this will stand up to the demands put on this section of the steering wheel.
    Any suggestions of how to 'seal' the cut ends of the steering wheel?
    Liked: 1262
    Maybe a cap over the insides...
    https://www.mcmaster.com/end-caps
    I would question the integrity of one that was cut though.
    Lafayette INdiana
    Liked: 295
    I would worry about the strength too. Cutting it out of a piece designed as a ring structurally might cause trouble with the spokes.
    I can't use a butterfly wheel in any case as there is not enough room for my elbows. I have to walk my hands on the wheel when more lock is needed.
    St. Louis, MO
    I stripped the swede from the cut out part and superglued it to the cut ends. It lasted until I sold the car.
    M
    Arizona
    Liked: 323
    Quote Originally Posted by Marty Nygard View Post
    M
    One side has exactly this done to it. The other side I will assume at some point had that as well. It is now gone and the hard foam and steel are exposed on that side. I am thinking to get some kind of suede or heavy bottom weight fabric to super glue over that end. Then, I think I want to dip about 3" of each side into something to seal the end. I just don't really know what product would work the best
    I think I used this and it worked well.
    https://www.homedepot.com/p/Plasti-D...03-6/202196703
    Mine came with what appeared to be cane tips on the cut ends.
    West Union, IL USA
    Liked: 319
    Default garage art
    Unless the wheel in question had sentimental value, like it came off of Gilles Villenueve's F-Atlantic March, I'd buy a new wheel.
    Is a formula car steering wheel without the top part of the circle less strong or safe?
    Detroit area
    Liked: 141
    I understand they are banned in the UK (and EU?) for safety reasons.
    Mississauga, Ontario
    Liked: 902
    My pal uses Seal All to glue the suede down, then paints the visible seam black. Looks fantastic and the Seal All is super tough. He fixed my wheel this way, and it is holding up great
    cheers,
    bt
    Arizona
    Liked: 323
    Quote Originally Posted by billtebbutt View Post
    cheers,
    bt
    So, he didn't use this product to coat the end of the wheel? He had cut some of the left over suede into a circular piece and then used this product as a glue to stick those pieces to exposed part of wheel?
    I haven't ever heard of this product. Does it cure hard like JB Weld or does it stay a little bit pliable?
    https://www.tapplastics.com/product/...SAAEgLSA_D_BwE
    Senior Member David Clubine's Avatar
    Ontario Canada
    Liked: 160
    Quote Originally Posted by t walgamuth View Post
    Having dissected a couple of open top wheels that went past there useable life, you could see the saw marks from the factory.....
  15. #14
    Liked: 4349
    The best solution I have found is a JB Weld (black epoxy). You need to do each side separately so you can clamp the wheel with the cut-off face horizontal, then add a blob of epoxy. I expected to need several applications, but do it in one shot, ending up with a gloss black dome on each side. If you shape your blob like a Hershey kiss, it will settle down into a nice shallow dome.
    While there may be some sealing involved, I considered it a cosmetic endeavor and was pleasantly surprised by the result.
  16. #15
    Liked: 902
    Correct. It cures pretty hard. Worked great
    bt
