Results 1 to 9 of 9
    Burlington, WI
    Liked: 388
    Default Are "battery isolaters" scca approved?
    Anyone have any experience with using a battery isolator like those made by cartek and their approval by SCCA?
    I just installed a MSEL unit. It’s FIA approved. My interpretation is that SCCA will accept it.
    Liked: 1261
    San Jose
    Liked: 83
    Default Master Switch
    We use a simple toggle switch, a number 10 or 12 wire from the positive side of the battery to the toggle switch and from the other side of the toggle to "the car". We have used a simple high amp mil spec toggle or a mil spec toggle circuit breaker from Aircraft Spruce.
    Buffalo, New York
    Liked: 269
    Quote Originally Posted by sccadsr31 View Post
    A battery like we use can deliver 400 amps instantaneously at a breaker switch and you use a 2 amp toggle?
    What am i missing? Is it for a high voltage relay as used on homebuilt aircraft?
    San Jose, Ca
    Liked: 89
    The circuit breakers David mentions above are meant to be used as on/off switches, as compared to household type breakers that aren't.
    Burlington, WI
    Liked: 388
    Why did you choose the MSEL unit over the Cartek?
    Mike
    San Jose, Ca
    Liked: 89
    Don't think they're required.
    Mike
    Mike,
    Cartek XR is almost the same capabilities but MSEL has these differences as far as I could tell in my research:
    1)switches positive
    2)has CAN bus monitoring
    3)disconnect command via CAN signal is possible
    4)built-in short protection
    Mike
