Results 1 to 10 of 10
    Albany, NY
    Liked: 235
    Default Question on '86 Van Diemen
    I'm trying to determine what the front track is on a wide track '86 Van Diemen.
    Thank you in advance.
    Lafayette INdiana
    Liked: 295
    I don't know about an 86 but my 98 is 70"' to the top of the front tires so with negative camber would be a little wider.
    Lafayette INdiana
    Liked: 295
    I'm trying to determine what the front track is on a wide track '86 Van Diemen.<br>
    <br>
    <br>
    <br>I don't know about an 86 but my 98 is 70"' wide out to out at the top of the front tires so with negative camber would be a little wider.
    Albany, NY
    Liked: 235
    Thanks but those two cars are very different designs.
    Derbyshire, United Kingdom
    Liked: 313
    Jim - I have an RF86 FC. Will make some measurements and report back!
    Liked: 313
    Front track 60"
    Rear track 57"
    These are from my RF86, ex-Paul Tracy FC/F2000.
    Hope this helps!
    Albany, NY
    Liked: 235
    Thank you very much!
    Liked: 313
    Happy to help! If there's anything else just give me a shout.
    Contributing Member Comp89's Avatar
    Ottawa, Ontario. Canada
    Default Vd 86
    Not necessary the wide track info but according to VD book: front width 56" ;
    rear 56";
    wheel base 95";
    total width 66" .
    Source " Les Van Diemen" des Éditions du Palmier
    J-Guy
    Albany, NY
    Liked: 235
    The measurement I am working with shows the front track less the rear. So car definitely isn't wide track. Good to know.
