Results 1 to 11 of 11
    Ottawa,ON
    Liked: 138
    Default traction and fuel mixture knobs
    So I have 2 knobs, one marked Trac the other marked Fuel.
    The one Marked trac seems to have 12 settings, the one marked fuel has 4.
    Does this seem backwards? From what I could find in the documentation the fuel mixture should be at 8+ for 93octane so I'm thinking the knobs are marked wrong?
    I'm sure I'll have many more questions as I go through this car...
    Your knobs are correct
    Ottawa,ON
    Liked: 138
    Thanks. More stupid questions coming.
    Ottawa,ON
    Liked: 138
    Draining gearbox? Only by removing wing and gear cover or suck from top? Don't see a drain and current level is unknown.
    Oil will come out when you pull the rear cover (recommend at least every other event)
    Ottawa,ON
    Liked: 138
    Yeah was just hoping for the first time to not have to pull the cover sounds like the only way.
    That often eh? I only do 1 hour of track time per event so probably good for 3-4
    4-5 hours is decent interval. It’s a good preventative inspection. I’ve never found any issues in mine.
    Ottawa,ON
    Liked: 138
    Ottawa,ON
    Liked: 138
    Anyone know the fuel cell size? I googled a lot, lots of available cells to buy, they just all say "fits pro formula mazda" but don't say the size...
    I believe 18 gal but I’ve had a long day LOL
    Ottawa,ON
    Liked: 138
    I had heard 70L so that makes sense. Geez that's huge. Larger than my street car. Actually almost the same size as my truck lol
