Results 1 to 15 of 15
    Contributing Member cjsmith's Avatar
    Columbia SC
    Liked: 95
    Default Formula car engine separation lift
    I purchased my FF a few years ago and at one point had to remove the engine due to damaged valves due to missed shifting. I used my engine hoist to split the engine from the frame which was a PITA to separate and worse to re install. I had seen people that had nice aluminum overhead gantry cranes that they could assemble any where but looked like you needed a lot of room to store them. I do 95% of my work on the car by myself, hence need to find a simple way to do whatever needs to be done on the car. For my situation, I came up with an easy solution to splitting the car and didn’t take up much space. I made a simple A frame lift I could place over the car that would support the front of the drive train as I disconnected it from the frame, then roll both backwards. With the lift I can install or the engine in 20 minutes or have it out in 5, assuming everything has been disconnected. It’s easy to store and has saved me at the track a number of times. It has a simple Eye bolt that connects to the front of the engine, or I can sling the engine if I have to remove the bell housing from the engine after the drive train has been removed from the car.
    If anyone is interested, I can send you directions on how to make one. I don’t have mechanical drafting programs at home, So I don’t have a formal model and print. I made up a short and simple directions and material list that should cover building one assuming you have decent welding skills and have some steel fabrication ability.
    Mokena IL.
    Liked: 59
    What a great idea, well executed. I could have used it last month. I'll have a copy of the plans thank you very much.
    tomallan57@sbcglobal.net
    new zealand
    Liked: 110
    Fantastic idea. I think I will build two; one for the engine, other for the gearbox. I imagine one at each end of the car could easily get it onto the stands too. A proper gantry can take up lots of space and I have too much to take trackside already. Can you send me the plans? Either PM or mark.elder@cdhb.govt.nz. Thanks in advance.
    Mark
    Contributing Member phantomjock's Avatar
    Red Neck Riveria, FWB, FL
    Liked: 105
    Default Copy 4 me 2 Please
    PM here, or chainplates-AT-hotmail-DOT-com
    Great idea - Thanks for sharing!
    Cheers - Jim
    Burr Ridge, Illinois
    Liked: 301
    Default "Lift" drawings...
    PM sent.
    San Antonio, TX
    Liked: 37
    Default Yes, Please
    Smith0290@yahoo.com
    Greg Smith
    Howell, MI
    Liked: 218
    Great idea - perfect size to stick in the trailer. Hit me up too! cade@wrenchaholics.com. Thanks!
    Cade
    www.wrenchaholics.com
    Rental, Coaching, and Data Analysis for Great Lakes Region
    Columbus, OH
    Liked: 69
    I like it!
    craig71188@hotmail.com
    Please and thanks!
    Craig Butt
    Columbia SC
    Liked: 95
    Default Car lift drawings
    I'll send the drawings out tonight. I'll add the drawing to this thread as well, getting more requests that I expected.
    I won't be racing at the Runoffs but will be there. If anyone wants one and doesn't have the time or place to make one I can make one and bring it there, $225 delivered to the track.
    Leominster Ma.
    Liked: 20
    Looks great and stores easily. Can you send me a copy of plans lentumenas@gmail.com
    Thanks Lenny
    Columbia SC
    Liked: 95
    I tried to upload the directions but the file is over 2 meg, due to the pictures, even with them compressed. Looks like you will have to send me a message and I can send you the directions. I have the material list with it.
    Chris
    New Jersey
    I would also like a copy of your plans. Thank you. mikekondrla@gmail.com
    lambertville, Michigan
    Liked: 46
    Me too. Please send me a copy of the plans and a material list. Thank you, Steve
  15. #14
    near Athens, GA
    Liked: 830
    Quote Originally Posted by cjsmith View Post
    Chris
    With his permission, I have uploaded Chris' files to my website where anyone can download them. Links...
    http://www.WedgeRacing.com/CJS/Car_l...mith_2019.xlsx
    and if you're scared, or your browser won't allow you to open an Excel file directly, there's
    http://www.WedgeRacing.com/CJS/Car_lift_CJSmith_2019.zip
  16. The following 3 users liked this post:
  17. #15
    South Carolina
    Liked: 673
    Been awhile since I saw something new and cool for formula cars. That was thinking out of the box.
    Swift DB-1
