Thread: oil pressure
    cambridge, massachusetts
    Default oil pressure
    Where, what port do you get your oil pressure from? GSX R600 Also, anyone know what thread/pitch is the oil pressure sending unit is?Thanks, Will
    Huntsville, AL
    Liked: 57
    I use one of these https://www.pegasusautoracing.com/pr...oduct=3228-304 in the line between the main gallery and the oil cooler.
    I don't know about the sending unit thread spec.
    George Bugg
    NovaKar
    F600
    George,
    Thank you for the reply and part number. Have ordered, should be here Friday.
    Was hoping to use the sending unit hole. Looks like its a pipe thread [tapered] .9mm pitch not sure of the diameter.
    Will
