This is a thread expanding on some of the things recently discussed in the Cylinder Head Temp thread.
My research indicates that the fin design of the stock VW engine is probably limited to the amount of heat rejection it can provide. Some kind of high pressure forced air blower is going to be required to get the cooling efficiency required for a 62 HP race engine... without also using an overly rich A/F mixture.
What I am getting at is that you can produce more HP using the ideal A/F ratio for max power. I am not sure you can accomplish this with the current fin design, certainly not without a significant increase in aero drag. A highly efficient oil cooling system is your only option to increase engine cooling.
