Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
  1. #41
    Finally a simple answer to a simple question.
    The OP simply asked about gearing, not a many post debate on HP and where to shift.
    Actually, he asked many questions in the OP. Including, specifically: Am I understanding this right that absent a big drop off in torque curve, it is almost always better to go up to redline than to shift up?
    Tony Kester used to travel around giving a driver's seminar and he said to gear a tad tall. It makes you drive the corners harder cause it sounds like you are going too slow. YMMV
    I like that theory. I also like the one where you gear a bit lower than everybody else to get a better start, recover from mistakes/balked by traffic quicker. Then a bit taller on top so that you can utilize the tow off of cars in faster classes. Damn! Need more gears!!!!!
  2. #42
    Daryl...
    In my first post in this thread, I said:
    "The correct way to select shift points is to maximize the area beneath the power curve."
    So you're not correcting me when you say that. I already understand it.
    What I was correcting is your response to me stating that the shape of the curve and gear ratios are factors, to which you replied:
    No. It absolutely would not. This is mathematics, and it is undeniable
    Then you go on to respond to to borkracing's comment which begins with :HP being a number derived from Torque and RPM's with this gem:
    Sorry, but that is completely and utterly wrong.
  3. #43
    Buffalo, New York
    Liked: 269
    Apexspeed is an incredible resource.
    It is, however, on the internet. No level of expertise or knowledge is required to post ..... usually just an opinion.
    Being successful in racing, is totally about the people you choose to guide you, and what guidance you choose to embrace. Now ...... that is undeniable!
    And many people would rather do it their own way, than be successful.
    Enjoy your project!
    Listen to this guy. He helps build winning racers.
  5. #44
    Buffalo, New York
    Liked: 269
    A simple thought example.
    Imagine an engine with a very low torque peak at (say) 2000rpm, but where that torque only falls very slightly to the (say) 10,000rpm redline, say from 100ft-lbs to 90ft-lbs.
    Now, if you can choose between being at 10,000rpm with 5:1 reduction compared to 2000rpm at 1:1 relative reduction (for the same output shaft speed:
    Which will give you more output torque? The math is easy.
    5:1 speed reduction means 5 * 90 = 450ft-lb torque at the output shaft.
    1:1 means you get 100ft-lbs at the output shaft.
    Still think HP beyond peak torque is just for bragging rights?
    The power figure combines both the torque you're getting AND the amount of reduction you can apply to that torque before it gets to the wheels.
    The power curve rules.
    Apples to oranges. Lets compare same to same
    Are we talking engine torque or torque delivered by the gearbox?
    5:1 at 2000 RPM has more torque than at 10,000 RPM, as you showed gears are torque multipliers.
    HP can be calculated at any gear ratio, but needs to be 1:1 when comparing car to car because of course a car in 1st gear will have more available torque than when it is in top gear.
    Enjoy your arguments gentlemen. I am out of here.
    Robby
  6. #45
    Vancouver BC
    Liked: 471
    I was comparing same to same. Of course I'm talking engine torque.
    At any given road speed, you will get different engine RPMs in different gears. I gave you a theoretical way of describing a situation.
    You can't use 5:1 @ 2000 if you were just using 5:1 at 10,000. You have to use 1:1 if the road speed is constant.
    So if you have 100ft-lb at 2000rpm at the engine, then at whatever road speed you can use a 1:1 ratio for, you MUST use a 5:1 ratio at 10,000rpm. Ergo, you get 5 times whatever torque you have at 10,000rpm delivered at the wheels. For any engine torque more than 20ft-lb, that means you'll get more torque at the wheels.
    Examining the power curve just combines those two quantities into one. Since HP = torque (in ft-lb) * RPM / 5252, 100ft-lb @ 2000 rpm is...
    38HP.
    Do you want to take a wild stab at what 20ft-lb at 10,000 rpm would be?
  7. #46
    Buffalo, New York
    Liked: 269
    No
    You are talking gearbox torque and claiming it is engine torque.
    Yes, torque at the output shaft changes, at the flywheel it does not.
    I am happy you have discovered math, enjoy yourself.
    Once again, I am done. Find someone else to argue with. Good day
  8. #47
    Vancouver BC
    Liked: 471
    No
    No. I'm really not. I'm talking about engine torque at one end of the system, and what the gearbox does to multiply that torque.
    It changes at different RPMs, Robert.
    Do I have to make it concrete from end to end?
    No one forced you to come back and argue with this. Don't get all huffy.
  9. #48
    Texas
    Default Brilliant ! Now if only you had these for a 9:31 Pinon MK8-
    Any suggestions for 9:31 MK8/9 GB Formula Ford? Thx
    Quote Originally Posted by Jay Laifman View Post
    I put the chart in a spreadsheet and calculated the speed at redline (assuming 7k, 22" tires, 10/31 R&P) and then the spread of mph between redlines for the gears. It further shows how little consistency there is in that as well, and how track specific it really is.
    Track 1st Gear
    Speed at 7k redline
    2nd 3rd 4th Gap b/w 1st and 2nd
    @ Redline
    2nd and 3rd 3rd and 4th
    Atlanta Motor Speedway 19/31
    91
    22/30
    108
    24/28
    127
    23/24
    141
    17 19 14
    Blackhawk Farms Raceway 18/32
    83
    20/31
    95
    22/29
    112
    21/25
    124
    12 17 12
    Brainard International Raceway 18/34
    78
    20/30
    99
    23/28
    121
    23/24
    141
    21 22 20
    Carolina Motorsports Park 17/29
    86
    17/25
    100
    22/29
    112
    24/27
    131
    14 12 19
    Charlotte 19/31
    Same as Atlanta
    22/30 24/28 23/24 17 19 14
    Corpus Christi (2.8 mi. Course C) 19/33
    85
    20/31
    95
    21/27
    115
    24/26
    136
    10 20 21
    Daytona International Speedway 20/30
    99
    22/30
    108
    24/28
    127
    23/24
    141
    9 19 14
    Des Moines 17/34
    74
    19/33
    85
    21/30
    103
    23/29
    117
    11 18 14
    Firebird International Raceway 19/33
    85
    21/31
    103
    22/29
    112
    24/27
    131
    18 9 19
    Gateway International Raceway 18/32
    83
    20/30
    98
    22/28
    116
    24/26
    136
    15 18 20
    Gingerman Raceway 17/33
    76
    19/31
    91
    21/30
    103
    22/28
    116
    15 12 13
    Grattan Raceway 17/34
    74
    19/32
    88
    22/30
    108
    24/26
    136
    14 20 28
    Hallett Motor Racing Circuit 16/35
    68
    18/33
    80
    20/30
    99
    23/28
    121
    12 19 22
    Heartland Park Topeka 17/34
    74
    20/31
    95
    22/29
    112
    21/24
    129
    21 17 17
    Indianapolis Raceway Park (Oval) 19/31
    91
    21/31
    103
    24/28
    127
    23/27
    126
    12 24 -1
    Indianapolis Raceway Park (Road Course) 18/32
    83
    20/30
    98
    23/29
    117
    25/27
    137
    15 19 20
    Lakeland 18/32
    83
    20/30
    98
    22/29
    112
    23/29
    117
    15 14 5
    Lime Rock 20/30
    99
    21/29
    107
    23/29
    117
    24/26
    136
    8 10 19
    Memphis Motorsports Park 17/33
    76
    20/33
    90
    22/29
    112
    24/26
    136
    14 22 24
    Mid Ohio 18/33
    81
    20/31
    95
    21/29
    107
    21/24
    129
    14 12 22
    Moroso 17/33
    76
    19/31
    91
    24/28
    127
    24/26
    136
    15 36 9
    Mosport 18/34
    78
    20/30
    98
    22/28
    116
    24/27
    131
    20 18 15
    Nelson Ledges 18/33
    81
    20/30
    98
    23/29
    117
    24/26
    136
    17 19 19
    New Hampshire International Speedway 17/33
    76
    20/31
    95
    23/29
    112
    24/26
    136
    19 17 24
    Phoenix (Road Course) 16/34
    70
    19/31
    91
    21/29
    107
    21/24
    129
    21 16 22
    Portland International Raceway 19/31
    91
    21/29
    107
    24/28
    127
    24/26
    136
    16 20 9
    Road America 18/32
    83
    20/30
    98
    23/28
    121
    23/24
    141
    15 23 20
    Road Atlanta 19/32
    88
    21/31
    103
    23/28
    121
    23/24
    141
    15 18 20
    Roebling Road 19/32
    88
    21/30
    103.5
    23/28
    121
    24/27
    131
    15.5 17.5 10
    Sears Point 17/34
    74
    20/31
    95
    22/29
    112
    24/27
    131
    21 17 19
    Sebring (Long Course) 18/34
    78
    20/30
    98
    24/28
    127
    24/26
    136
    20 29 9
    Sebring (Short Course) 17/33
    76
    19/31
    91
    22/29
    112
    24/27
    131
    15 21 19
    Shanonville 16/34
    69
    19/31
    91
    21/29
    107
    23/28
    121
    22 16 14
    St. Petersburg 17/33
    76
    19/31
    91
    22/29
    112
    24/27
    131
    15 21 19
    St. Jovite 17/35
    72
    19/31
    91
    22/30
    108
    24/27
    131
    19 17 23
    Summit Point 19/33
    85
    20/30
    98
    23/29
    112
    24/26
    136
    13 14 24
    Texas World Speedway (1.8 "school" config) 19/32
    88
    22/30
    108
    23/28
    121
    23/24
    141
    20 13 20
    Texas World Speedway (2.9 config.) 18/33
    81
    20/30
    98
    23/29
    112
    24/26
    136
    17 14 24
    Trois Rivers 17/33
    76
    19/32
    88
    21/30
    103
    23/28
    121
    12 15 18
    Virginia International Raceway 18/33
    81
    20/30
    98
    22/29
    112
    24/26
    136
    17 14 24
    Waterford Hills 17/34
    74
    19/31
    91
    21/31
    100
    22/29
    112
    17 9 12
    Watkins Glen (Long Course) 20/30
    99
    21/30
    103
    23/28
    121
    24/26
    136
    4 18 15
    Watkins Glen (Short Course) 20/32
    92
    21/30
    103
    23/28
    121
    24/26
    136
    11 18 15
    Willow Springs 19/32
    88
    21/30
    103
    22/28
    116
    24/26
    136
    15 13 20
  10. #49
    Destin FL
    Liked: 646
    The proper answer to this question:
    Ask knowledgeable experienced racers that are successful (and faster than you) with similar cars what ratios they use.
    Use those ratios until you find a better advisor or identify a problem that can be solved by some of this engineering mumble-jumble .... or just plain common sense.
    Greg, tact
  11. #50
    Quote Originally Posted by Jbird57 View Post
    Thank you Scott Young.
    Attached Files Attached Files
  13. #51
    Liked: 4353
    Greg, tact
    I believe that my message is completely accurate and that an expanded version should be posted on every shop wall.
    "Do what successful people do. Learn and evolve!"
  15. #52
    Destin FL
    Liked: 646
    Greg:
    I concur completely, your message was spot on. “Lean on them, and most likely, fellow racers will share”.
    In the early 70’s, there was a rag we all subscribed to in Autoweek. And a fellow racer, whom has formidable racing credentials, submitted an article on gear selection. He used a pseudo math solution that was not available at that time. So actually friend, math counts. May not be 100% accurate, but gives one a starting point.
    Lastly, I spent a little time in the military, and learned quite quickly about …… conversation, both written and spoken. There is a source, a message and a receiver. And the most effective way to, persuade or mentor, is to be amicable.
