Have a socket head cap screw that holds the steering arm to a billet aluminum front upright. Replaced a few weeks ago just as preventive maintenance. Loosened the screw to remove shims and it began to bind up. It was not cross threaded. HAd to cut the head off the bolt, installed 2 jamb nuts to double nut it, and I just stretch the threads on the nut. Applied heat from a heat gun, and still no luck. Open to suggestions other than wire EDM.
Bob
