Results 1 to 16 of 16
    Columbus, OH
    Liked: 482
    Default Please recommend a leak down tester
    I have a compression tester but I need a leak down tester for more info. There seems to be a range: cheap Harbor Freight (which I usually avoid like the plague) up to fairly expensive SnapOn (which would be my preference if I hadn’t already killed my budget). There are several that I don’t recognize the name but could be good. Can anyone make a recommendation? Would be nice to be under $100 but I don’t want crap that isn’t reliable so if it needs to be over that, so be it.
    Liked: 3279
    Default Home-made leak-down tester
    I built my own many years ago using 2 60-psi gauges I had accumulated over the years, a cheap regulator, and pieces of 1/4" pipe & fittings. I made adapters out of old spark plugs.
    There is a 0.020" dia orifice in the pipe between the gauges, so it is more accurate than the usual LDT for small engines in good shape. I do the leakdown at 50 psi. It works very well.
    Photos below:
    Columbus, OH
    Liked: 482
    Default Wow
    That looks simple enough... thx.... off to search McMaster...
    Exactly what I did except I used a flow control for the orifice and made a plug to pt in the end of the hose with an 0.030" hole in it to be able to check calibration. Yep just braze a quick disconnect fitting on an old spark plug and you are in business.
    Torrington CT
    Liked: 479
    I went looking for the company I bought a unit from 30 years ago and I think this is the current iteration.
    this looks interesting
    https://aircraft-tool.com/shop/detail.aspx?id=2EM-KIT
    no endorsement - just a price point and sample.
    and I looked just for fun
    https://www.harborfreight.com/search?q=Leak%20down.
    ChrisZ
    Liked: 1261
    https://www.summitracing.com/search/...down%20Testers
    I think Performance Tool is the same source as HF.
    Total Seal makes rings so they should make a decent tester.
    I have a longacre.
    For most you will need to make an adapter.
    Banned
    Liked: 1116
    Mine is a Tavia. Not sure if they are still available. . . cursory google search did not come up with one. Gauges are made by Ashcroft in CT.
    I'm fairly frugal, so I can't imagine I spent a whole lot on the tool, maybe $100, but probably close to 20 years ago.
    There's a set USED on ebay right now for $90.
    Liked: 942
    I have one of these. Gauges are calibrated and matched with a .040" orifice. Designed for aircraft engines, I soldered the orifice closed and re-drilled to .020". I use the spark plug adapter from my compression tester. Ebay has a good selection, but avoid the Hazard Fraught model. Gauges are junk,
    https://www.google.com/search?q=East...w=1920&bih=944
    Liked: 1474
    Got mine at Aircraft Spruce nearly 20 years ago.
    Saint Charles, Mo.
    Liked: 14
    Default Snapon leakdown tester
    I have an old Snapon I'm not using if you're interested. $75.00 plus shipping from 63303.
    NC
    Liked: 302
    Back when I was a kid I did what DaveW did and just built it as I had the parts lying around. A couple years back when I started again I did not have parts lying around and the cost was about the same as just buying one - OTC.
    Works fine.
    https://www.amazon.com/OTC-5609-Cyli...-1-spons&psc=1
    Senior Member Wes Allen's Avatar
    Lexington,Ky.
    Liked: 64
    While on this topic,anyone care to share the proper procedure for testing leakage? How to you find and keep the piston at TDC?
    Columbus, OH
    Liked: 482
    Quote Originally Posted by Wes Allen View Post
    Wes, I assume you mean Kent, correct? I can’t speak to that for certain...
  15. #14
    Lexington,Ky.
    Liked: 64
    Yes, I was basing my question regarding the Kent
  16. #15
    Liked: 3279
    Just locate the piston at TDC as closely as you can - it won't move off TDC as long as it is close. Friction will keep it there unless it's a decent ways off TDC. And using 50 psi (as I do) instead of 100 psi makes it easier to have it not move.
    Before I apply pressure to the tester, I wiggle the crank back and forth a few times to settle things in.
  18. #16
    If it is not at TDC on the compression stroke you will know right away. I just run an eyeball down the plug hole and wiggle the crank like Dave said. No magic tricks involved.
