Results 1 to 11 of 11
    Liked: 703
    Default Girling master cylinder ID
    I may be missing the obvious but can someone tell me what the bore diameter is in this master cylinder?
    www.gyrodynamics.net
    Liked: 854
    Looks like it says 3/4 (after Girling). Was it on the front?
    Petaluma, CA
    Liked: 565
    I think that it says 3/4 right there BUT sometimes the lettering on the side of Girling master cyl’s is tough to read.
    Ethan Shippert
    https://www.norwestff.com
    Liked: 703
    It's very hard to read but now that you point it out, I can see where that might say 3/4. Must have been toward the end of that mold's life. Thank you!
    Senior Member Bob Clark's Avatar
    Glendale, WI
    Look 180 degrees and the same info should be on the other side also. Might be easier to read.
    Liked: 703
    Quote Originally Posted by Bob Clark View Post
    It was actually worse!
    Glendale, WI
    Figures..You can always take it apart and measure the bore.
    Liked: 703
    It is coming apart but I wanted to have the right rebuild kit on hand so I can put it back together right away. Order coming your way soon!
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 601
    Default Girling bore size
    3/4 inch.
    Keith
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
    CA
    Liked: 246
    The 3/4 is difficult to read on all the cylinders I have ever seen. The good news is the other common sizes 5/8 and .70 are much clearer so if it doesn’t say one of those chances are pretty good it is 3/4. The one pictured is definitely 3/4 in my opinion. Todd
    Tacoma, WA
    Liked: 322
    Original Girling master cylinders have another casting mark that denotes the diameter.. if the cylinder has a single “ring” cast around it (like the one in question) it is a 3/4”, if it has 2 “rings” it is a .70”, and if it has no cast rings it is a 5/8”.
    sometimes the .70 has a full ring and the second is a second ridge that doesn’t go completely around the cylinder.
    Lockheed had something similar, I don’t use them so I don’t have the specifics.
    hope that helps someone in the future.
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
