I'm reviving an old FM gearbox - standard stuff with vw case, hewland guts and webster side covers, I think 400s (have bosses for inboard brakes).
The oil seals are cracked and I need to replace them...several questions...
1) It looks like you need to heat the side covers to drop the entire bearing/shim/seal stack out the back side of the cover? Any tips on doing this? Simple as just heating around the hole, and the lot just drops out the bottom or does it need to be persuaded out?
2) If 1 is true, then I assume the reverse is also true for putting it all back in with the new seals? If so, seems kinda scary to have a lot of heat around the rubber of the oil seals and sliding all that stuff back in before the side cover cools seems like it takes some technique. Again, any tips here?
3) Having done 1 & 2, assuming all the same shims go back in, just with a new seal underneath, do I need to worry about differential bearing pre-load or all is well assuming it goes back together with the same bits as came out?
Any advise here is welcomed...Thx!
Chris
