Thread: AN -10 fitting
    Destin FL
    Liked: 645
    Default AN -10 fitting
    Gents;
    Any ideas where to find several of these? The smallest I can find is AN-12.
    V/r
    Contributing Member phantomjock's Avatar
    Red Neck Riveria, FWB, FL
    Liked: 105
    Rick -
    A fairly new machine shop here in town CNCs a variety of aluminum AN fittings. Mostly set to weld up - but I be they could build that for you. Web page is emeraldcoastmotorsports.com send the pic to mike@...... and I bet he'd have an answer. Standard disclaimer -- Just used them to work inserts for my uprights. Good work.
    Cheers Jim
    When I used to fly Phantoms, I was called an AVIATOR.
    Now I race cars. So, am I now called a PAVIATOR?
    Vancouver BC
    Liked: 470
    What's it for? Just curious.
    Vancouver BC
    Liked: 470
    Gents;
    V/r
    If those fit in all other respects, get this:
    https://www.jegs.com/i/JEGS/555/110225/10002/-1
    Detroit area
    Make a square base
    - cut down an AN10 fitting
    - weld together.
    Bob's your uncle.
    Making special fittings that way for space or 'odd-ball' reasons
    just becomes normal. I also used to drill bigger holes through most
    oil fittings - we only run 100 psi or so.
    Probably for an oil pump port.
    Liked: 139
    Aviaid pumps. There are some bolt on's on their pump photos but don't see them on their web site. Size? also.
