Gents;
Any ideas where to find several of these? The smallest I can find is AN-12.
V/r
Iverson
Gents;
V/r
Iverson
Rick -
A fairly new machine shop here in town CNCs a variety of aluminum AN fittings. Mostly set to weld up - but I be they could build that for you. Web page is emeraldcoastmotorsports.com send the pic to mike@...... and I bet he'd have an answer. Standard disclaimer -- Just used them to work inserts for my uprights. Good work.
Cheers Jim
What's it for? Just curious.
If those fit in all other respects, get this:
https://www.jegs.com/i/JEGS/555/110225/10002/-1
Make a square base
- cut down an AN10 fitting
- weld together.
Bob's your uncle.
Making special fittings that way for space or 'odd-ball' reasons
just becomes normal. I also used to drill bigger holes through most
oil fittings - we only run 100 psi or so.
Probably for an oil pump port.
Aviaid pumps. There are some bolt on's on their pump photos but don't see them on their web site. Size? also.
