Results 1 to 11 of 11
    Default Oil Pressure needle stuck at 80 lbs. Gauge junk?
    I have a Race Parts combination mechanical oil pressure and oil temperature gauge. Recently noticed the needle was straight up at 80 lbs.
    It seems like I've heard of this problem before. I was able to pull the needle towards zero with a magnet, but it instantly sprang back to 80. I shot a blast of air into the hose and the needle would rise above 80, so there is some working mechanism in there. I don't know if my blast of air was 10 lbs or 90, though.
    Just wondering if it is worth fooling with, or if it's time to replace it. Luckily I have an oil pressure sensor for the dash (with alarms), so it's not critical. Just nice to have.
    Thank you.
    lambertville, Michigan
    Liked: 46
    Ask the experts. Email the company and see what they say.
    Pittsboro IN
    Liked: 280
    I would never be able to trust it. Replace it.
    Liked: 854
    Quote Originally Posted by steve zemke View Post
    ^^ Practical answer.
    The cheap owner of my team says to take it out, clean out the line, tap it, put a low regulated air pressure in and see if it becomes unstuck.
    The crew chief of my team says throw it away nd never look back. A faulty oil pressure gauge is worth less than a cheating spouse.
    Senior Member kea's Avatar
    madison heights,mi
    Liked: 601
    Default Oil Pressure Gauge
    Junk.
    If you take one apart and see what makes this style pressure gauge work (same as Smith) then you would understand that something has happened to it mechanically and it should not be trusted.
    Averill Racing Stuff, Inc.
    www.racing-stuff.com
    248-585-9139
  9. #6
    Detroit area
    Liked: 141
    Go digital.
    or VDO.
    Late Braking Member
    Danville, California
    Liked: 217
    I agree with Keith, Junk. A new mechanical Racetech dual gauge from Demon Tweeks is about $150 including shipping...
    https://www.demon-tweeks.com/us/racetech-oil-pressure-water-temperature-dual-gauge-247035/
  12. #8
    Liked: 432
    Sell it to someone who has a motor with no oil pressure. They will be good to go.
    Graham
  13. The following 9 users liked this post:
  14. #9
    Mississauga, Ontario
    Liked: 899
    Default i can answer the question w/o looking at the needle...
    ...All I had to see was the brand. It was junk when originally installed, and still is junk....
    best,
    bt
  16. #10
    Thanks, all. It will be trashed and replaced.
    In my last car (big fat Spec Miata), I had Autometer Elite electrical full sweep gauges with programmable warning lights. They were nice. Any opinions on them or something similar? I'll need 2 1/16" size.
    My mechanical gauges are redundant to my dash display, but I'm old school and instinctively look at the round dials first.
    Buffalo, New York
    Liked: 269
    Stack gauges are autometer products now. They use standard sending units as found in a lot of dashes and data systems. FWIW
