Gents;
Assuming I can locate a distributor gear for my Titan pump, I’ll have two issues to address as I understand it:
- The gear will need a couple thousands removed to fit the shaft;
- Hole cross drilled for the pin.
First and foremost, is there a possibility a GOOD machinist can precisely duplicate the gear hole to match the existing hole in the rotor shaft.
If not, can a new hole through the gear and shaft be drilled 90 degrees from the existing hole in the shaft.
V/r
Iverson
