I can't get my vintage car to run other than pumping the throttle continuously. I think no fuel is getting to the low speed circuit. After much investigation I blew air and poured cleaner fluid over the top of the gasket surface as shown below. I think passage #1 and passage #2 are both supposed to be connected through a cross drilled passage lower in the carb body. If you look closely, you can see that the cleaner fluid is standing in passage #2 so it must be blocked somewhere. The cross drilled passage has plugs in both ends so can't see how to clean it out. Ideas?
