Hey everyone,
I'm hoping to put the engine/trans back in my Swift SE-1 shortly. I have a couple of clutch options, both QuarterMaster, one V-drive, one older (pro?). Of course, the spring colour codes have worn off.
The QuarterMaster catalog lists a process for measuring them.
https://www.quartermasterusa.com/wp-...16-Catalog.pdf Page 70.
Unfortunately, this doesn't make much sense, right? A .560" diameter piston would give a piston area (pi * radius^2) of 0.24 sq-in. If they meant a piston radius of .560" (diameter of 1 1/8"), it would be a piston area of 1 sq-in. That would let me read the gauge pressure (pounds per square inch) directly as pounds. I'm pretty certain this is just a typo.Originally Posted by QuarterMaster
Next, a 2-3/8" bearing? that's a 60mm release bearing, on a 7.25" clutch? If that's correct, our typical 44mm release bearing requires 73% of the force listed below.
I've tried contacting QuarterMaster, and they just want me to send the clutches in for them to measure for me. Time dictates I'd rather not go this route.
Has anyone measure these themselves? What parts did you use? What's wrong with my reasoning above?
Thanks!
