I'm specifically working on a VFF and this is the first car I've had with the external slave with a rod that actuate the lever, which engages the TO bearing.
I've rebuilt the clutch master and external slave but can't seem to get enough movement to disengage the PP. Also new TO bearing and new bushing on the F3-style bobbin.
Per a friend, the rod can barely move up and down and rotates with my finger with no pressure applied. It makes sense that there is no pressure on the TO bearing when disengaged.
Any hints on getting clutch disengagement? It sure would make life easier on me!
