Results 1 to 10 of 10
    Londonderry, NH
    Liked: 17
    Default Momemtary Switch for Lift
    My switch died on my vee lift. I would like to replace it with the one that it came with.
    Center off - Press one side up, other side goes down. I tried Grainger. Anyone know part number or manufacturer?
    john
Name:	2019-03-19 14.49.30.jpg
ID:	84301   Click image for larger version.
ID:	84302   Click image for larger version.
Name:	2019-03-19 14.49.14.jpg
    John Ferreira
    FV 15
    Londonderry, NH
    Liked: 17
    Quote Originally Posted by nhJohn View Post
    john
    For people who got the drawings to build their own, was there a reference to a part number or supplier?
    John
    John Ferreira
    FV 15
    Liked: 1879
    You should be able to find something close from McMaster-Carr.
    Member beavertail's Avatar
    Montreal, Quebec
    Default Up/down switch
    If you cannot find the same one, try looking for window up/down switches used in passenger cars. They have the same "current reversing" , "momentary" and "center off" function as your switch. Older cars in particular have switches which handle higher current loads and have the same spade connectors.
    Wilson
    Ocala, FL
    Liked: 43
    Tacoma, WA
    Liked: 323
    A simple DPDT-CenterOff switch will work a s well. The two battery poles go to the center connections and the winch wires are attached to connections on one side of the switch (would operate if the switch was moved that direction). Short jumpers need to be made that ‘cross over’ from one outside connection to the opposite connection on the other side of the switch, basically reversing the poles of the winch.
    https://rollertrol.com/DC-motor-reverse-switch-diagram
    -John Allen
    Tacoma, WA
    '82 Royale RP31M
    Londonderry, NH
    Liked: 17
    Quote Originally Posted by scorp997 View Post
    McMaster Carr - good idea ... looked, but not there, same as Grainger.
    Window switches. Good idea, went to rock auto, which led me to Doorman, but most of their switches are for regulated motors.
    Well, I have the DPDT from Grainger which I can cross wire, but still like the original because it fits nicely in a very sturdy box.
    But thanks for all the suggestions.
Name:	2019-03-23 14_12_46-Photos.jpg
    John Ferreira
    FV 15
    Liked: 1879
    Look also in Newark. Their catalogue and web site are a nightmare, though, so you will need many hours of free time available.
    Lapeer, MI
    Liked: 91
    Londonderry, NH
    Liked: 17
    Quote Originally Posted by TDI PILOT View Post
    I wish …. requires a relay.
    John Ferreira
    FV 15
