Results 1 to 10 of 10
Thread: Gasket sealer?
    Prescott, AZ
    Liked: 182
    Default Gasket sealer?
    What are your favorites for:
    -cork, pan, valve cover
    -head, composition
    -head , copper
    Liked: 909
    Cork RTV On pan, depending can dispense with gasket, use the end seals and a thin layer of RTV in place of the cork. Especially if the pan is stressed as in Swift and Citation and I ma sure others. On valve cover put sealer against cover so it does not wind uo glued to the block.
    Head Nothing If head and block are both true and flat and head is properly torqued never ever have had to use anything
    Senior Member Rondo's Avatar
    Delaware
    Liked: 22
    Default Pan Seal
    On the pan we use the black permatex....make sure you follow the directions on how long it sits before application, how long before torqueing, how long before in use and works like champ. In a hurry......you get a hurry up job you need to redo...but oil is cheap!!
    Prescott, AZ
    Liked: 182
    Sure hate cleaning RTV off when it's done properly.
    Yamabond has become a favorite on non critical areas.
    surprised at my engine tear down to find copper coat on the head gasket.
    Fallen Friend Bud Pug's Avatar
    Summit Point, WV
    Liked: 18
    Do you know who built the engine?
    San Diego,Ca
    Liked: 490
    Default FF
    Ivey has copper coated head gaskets, especially on aluminium heads, to prevent water seepage for quite some time.
    Roland Johnson
    San Diego, Ca
    Delaware
    Liked: 22
    Default Copper on head gasket
    Curious - the one time i tried it I made a big smeared mess as the head gasket was not EXACTLY in place and moved after the head went on top. How do you avoid it. My engine always comes back from the builder using copper and it looks pristine when I remove the head!! Does it dry?
    Prescott, AZ
    Liked: 182
    I've done the same and the old aluminum paint deal a long long time ago. I'm under the impression a lot of head gasket manufacturers suggest dry . Seems a belt and suspenders deal.
    Prescott, AZ
    Liked: 182
    Quote Originally Posted by Rondo View Post
    Possibly a few old head bolts with the tops cut off, lightly screwed into the block to position the gasket and guide the head to place.
    slot the tops to use a screw driver to remove.
    San Diego,Ca
    Liked: 490
    Default FF
    When you build as many Ford engines each year as Jay does, usually you get some insights into what to do, and why.
    Roland Johnson
    San Diego, Ca
