Originally Posted by
Mike Summers
Good Evening group...……...I wanted to throw out a concern that I have relating to clutch pedal pressure and movement but may not have all of the relevant information needed.
So just putting the finishing touches on my MK10 LeGrand FF, the conclusion of a 6 year long project. Got in the car to adjust pedals and belts and found the clutch pedal pressure was so hard that it is not practical to be raced. Let me tell you what I have as far as parts go...…...the master cylinder is a new but older style Wilwood. Has .07 stamped on the side. The slave cylinder is new but only has "county" stamped on the side with a 7F stamped on the body opposite the plunger end. I went to the Wilwood site and could not find a picture of the master cylinder...…….most shown are newer styles that have a longer body with a remote reservoir. The m/c that I have looks like a traditional Girling...…..screw on cap, round reservoir is part of the body.
So, first question is what would be the correct size for the M/C and the slave cylinder?? I cannot tell you what the spring on the pressure plate is...……..purchased past my date of memory.
Can I get some input as to what parts and bore sizes I should be using??
Thank,
Mike Summers
Sacramento, Ca
