Results 1 to 5 of 5
    Wetmore, CO
    Liked: 109
    Default Stohr FB SCCA Data Logger Location
    Howdy,
    I know this was discussed in the past but I cant find it doing a basic search. Where did most people with Stohr FB's end up putting the SCCA Data Logger Bracket? I was thinking about putting it in front of my steering wheel.
    And I havent heard a lot of chatter about people or SCCA on the topic...
    Thanks in advance
    CJ
    Senior Member Farrout48's Avatar
    Florida
    Liked: 134
    Quote Originally Posted by cjahn View Post
    Howdy,
    Thanks in advance
    CJ
    I have a WF1 but the frame is similar. When I got the car, the EVO4 was located on the floor in front the cross beam under the main hoop. I found that my foot was hitting it during entry/exit plus it got a lot of debris. I moved it beside the upper supports running from the front hoop forward. It is up high where I do not contact it, etc.
Name:	EVO4 placement.jpg
    Wetmore, CO
    Liked: 109
    Quote Originally Posted by Farrout48 View Post
    Thanks but I was looking for a mounting spot where the SCCA Imposed Data Logger could be installed while on the grid....This is the "DNKTKPFSOL5 data box mount" required by SCCA rules for P1, P2, and FB classes effective 02/28/2014.
    Senior Member BURKY's Avatar
    Florida
    Liked: 444
    We always put the bracket on the rear wing mount, or near the rear of the car for easy access. That being said...Has anyone ever had a box installed by tech for FB?
    Paso Robles, CA
    Liked: 285
    We just mounted it to the cockpit side on our Stohr DSR:
Name:	SCCA Solo Mount - Stohr - 1 (1).jpg
ID:	83506   Click image for larger version.
Name:	SCCA Solo Mount - Stohr - 1.jpg
    David Ferguson
    Veracity Racing Data
    Shift RPM App for iOS
    805-238-1699
