Last few times I've run the car it seems like the steering is way too heavy - especially in high speed corners. A couple of us were discussing this and the fact that the caster effect causes you to try and lift the front of the car under downforce caught my attention. I haven't changed the front alignment settings - besides camber the specs for various tire brands - for years. Always 1/16 out toe each side, and Dave Freitas once measured caster at 13 degrees. There has been some changes to the car since then so I don't know how accurate that number is - but it's likely close.
Thought I'd try something different - On each side I lengthened the top rear by 1 1/2 turns and shortened the front to fit the mounting points, thus pushing the top of the steer axis forward - while it doesn't seem like a lot it sure changed the front toe!
just got the car back on the platform and was wondering what typical caster settings are for these cars, and what sort of performance differences I might see, if any.
will try to measure what I ended up with and post back in a few hours.
