Thread: FE Chassis #47
    Michigan
    Default -
    Car make: Formula Enterprise
    Car model: FE Chassis 47
    Class: FE
    Condition: Very Good
    Roller or turnkey: Turnkey
    It’s well sorted out with setup notes, setup sheets/binders. Car was gone through and setup by Alliance.
    Includes all the latest updates: Penske shocks, steering Apex joints, crush box (minor damage but still ok), floating rotors, thermostat, throttle cam, muffler, adj. sway bars, ECU flashed for AiM EVO4 data logger with GPS, AiM Formula Wheel & Dash, AiM Air/Fuel Mixture Sensor, Comprent Actuator Upgrade, helmet surround with quick release pins, dropped footwell (increases room for big feet) and new Odyssey battery in 2018. New jump starter battery. Internal cockpit side panels, in-cell fuel update kit to protect against ethanol. Dry-break for fuel pump out. Fuel test port. FIA Belts good through 2020. 3 sets of OZ wheels (black) - 2 sets used slicks - 1 set rains (one event). 1 set Transport wheels.
    SPARES list:
    • Alignment shims
    • Complete rear wing assembly
    • Side pod (left)
    • Transmission Parts – spare NEW dog rings (3), Complete Gear Sets NEW for Reverse, 1st through 5th plus two extra NEW 2ndgears as well as several gently used gear sets (well over $3k in new parts)
    • New front splitter
    • Used Radiator
    • Used Battery
    • Oil pump belt
    • Wheel hubs/nuts
    • Hub pulling kit
    • Side mirrors
    • New Oil filters (2)
    • 2 sets of new brake pads
    • Various front and rear spare wing end plates and mounting brackets/hardware
    • “Used” front wing and winglet
    • Several rods, suspension pieces, mounting brackets, etc.
    • Original actuator assembly that was replaced with the upgraded Comprent
    • Original steering wheel, dash and data system
    Tools included:
    • Toe alignment bars (Comprent) and front mounting bracket
    • Transmission/gear removal & assembly tool (Comprent)
    • Quick jack
    • Low jack stands
    • Front nose cone holder (mount whole nose assembly in a raised position on front of car during transport or mounting on wall for storage)
    SOLD. Car is located in Grand Rapids, MI. Delivery negotiable. Dave = 616 three 4 zero 9539. Fastkart1 at sbcglobal.net
    __________________________________________________ __________
    Michigan
    Great car; new price!
    Michigan
    sale pending
    Michigan
    Car is SOLD
