I purchased a Zink C4 last summer. I've asked a lot of questions and gotten a lot of great feedback. After disassembly I have been gradually replacing or renewing parts and slowly reassembling. I'm an experienced racer but new to FV as I have been retired and whizzy bits cars are too expensive. Very intimidating as everything I've learned over decades doesn't transfer except prep is still number 1. I was trial re-assembling my Z Bar. I discovered that It is badly twisted. When lying flat on the floor one end is 2 inches higher than the other. I didn't think a Vee saw the type of forces to twist a solid steel bar of 11/16 dia.With everything that has to be adjusted on a twin spring car to get it set up I'm not sure I can reach the goals with such a twist. Has anyone seen such a twist before? Is there sufficient length available on the bar to reach a balanced set up. The Zink Z bar is designed with a bend in the bar about halfway between the mounting on the car and the end of the bar so I don't have the same length to adjust the links as say a Lynx. I appreciate your feedback.
